TwinTurbo.NET: Nissan 300ZX forum - I live in VA so passing emissions won’t be a problem
Zbruh92
on October 31, 2017 at 12:56 PM
If you have deletes, you will Fail the Visual
posted by Cjw3
on October 31, 2017 at 07:05 AM
Typically if the cats remain it will pass the visual. As it sits the AIV, PRVR, EGR, and carbon Canister have been deleted. Is it possible to trick the ECU into thinking it still there?
With Cali emission JWT Ecu will EGR delete throw a code?
Zbruh92
21:36:17 10/30/17
Cjw3
07:05:04 10/31/17
I live in VA so passing emissions won’t be a problem -
Zbruh92
12:56:49 10/31/17
I did a search.. I knew I'd seen this somewhere..
Cjw3
20:03:55 10/31/17
Thanks. Turns out Z1 sells a bypass plug so I’ll try that (n/m)
Zbruh92
21:43:17 10/31/17
It's there for universal fitment
BlackholeZ
11:53:54 10/31/17
Federal ECU tune will eliminate the a CEL for lack of EGR
02:56:31 11/03/17
